Root NoFrills or SetCPU
Without using it, or some kind of cpu control app (ie rom toolbox or system tuner, both are free btw) you'll get the default clock speeds (245/998) and whatever the default governor is for the kernel you're running.
Do you think it's better than SetCPU? I don't use profiles whenever I use SetCPU, just the min and max and usually ondemand, interactivex, or smartass.
SetCPU is essentially the "golden standard" app for CPU adjustments. If your on a sense based ROM, why use anything else?
If its the price that is the issue, there are free releases of it.
Gov: Either Smartass or Interactive X.
And for a Max 1113 is a pretty safe bet for most people. Just experiment and dont hit "set at boot" until your sure its not going to cause your phone to bootloop.
Oh yea, I found the free ones, lol. SetCPU it will remain.
I would encourage you to support the dev by buying it from the market sometime in the future if you find yourself staying with SetCPU.
I know Interactive does but, does SA have a screen off profile or should I say not need a screen off profile? I haven't set any profiles up, just letting the governor do it thing to see results.
They both do, but i still have one set at 422 max. Don't ask how, but I have significantly lower CPU speeds (pie chart) when I have the screen off profile set than when I do without it.
