Nokia N8's USB OTG adapter with S2
sam142000
I was just wondering if Nokia N8's usb otg adapter would be compatible with S2.
I really wanna get an usb otg adapter for my S2 but I'm able to find one in India. So I was thinking of buying Nokia N8's adapter. They both have the same usb ports (i think) v2.
Can someone here clear this out for me?
As long as its Female USB A to male micro USB B adapter it should work. My OTG adapter is generic and cost $1.75 on eBay shipped from HK to Australia. Works fine.
Here are the details of the cable you need
Micro USB Host OTG Cable for Toshiba C6-01 N810 N900 C7
search item 140494876025 on ebay
edit: Sorry should have said I have this and it works.
