Help Non market app installation does not work
JED2910
I recently bought an LG Motion from Metro. It was working fine I could install non-market apps until it received the update. Not sure if the update does not allow non-market installations because I know that the check mark in security for non - market apps is ticked.
PS. I can get to the install app screens, but the install button does not do anything it stays solid, the only functional button is the cancel button.
Was your device rooted/unlocked before the update? It could of relocked your device...this might have some kind of issue with you downloading non-market apps..
do you use screen filter(screen dimming app) ? if you do disable it
