Root Noob need help!
rammstien
Okay so i just got this phone (First ever 'smart phone') now i am good with computers and all... but how do I remove cm7? and superuser?
So i basically want back to default but i want to still stay rooted... or unrooted... Idc anymore.. I have been working on getting the market for cm7 for like 5 hours.. and i am tired... its 3am... please help before i leave for chicago tomorrow
What shows up when I hold down power and down...
SUPERSONIC EVT2-3 SHIP S-ON
HBOOT-6.17.0001
HBOOT-6.17.0001
Welcome to the AF!!:):)
Looks like you are partially unrooted but the stock rom is not yet installed.
Did you install cm7?
I think you need to complete the unroot process outlined here...
http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html
Scroll down to the unrooting part and go to step 2 because I think the phone appears to have step 1 completed.
You will lose data when flashing the stock rom and recovery.
If you desire to stay that way, or re-root after finishing unrooting, that is up to you.
Read the entire unrooting process and you will see what I mean when I say step 1 was completed.
That phone was rooted with revolutionary. I rooted with my phone the same way but my bootloader is 6.16.1002, s-off. When whomever started to unroot the phone, it changed bootloader to 6.17, s-on.. and I believe they did not go to step 2--install stock rom/recovery. In order to reverse what was done to your phone, I believe the unroot process needs to be completed, then you can root it again...follow?;)
I have no Idea what I did... but for some reason it wouldn't download apps... and i did the gapp's things and what not... well after putting that on an all I used EVO_Radio_2.15.00.11.19
and now everything downloads fine so I am good, and i kind like cm7
Well alrighty then :) , I dont know what you did either but if it's all working well.....
Did you flash an ruu (rom utility update) or something?
