Ok so i finally got a droid.. the original about a month ago, it had the frg22d build . I love it, i had started researching droids before dx came into view.
So here it is last weekend i finally took the plunge and rooted using RSD lite, i installed the motorola drivers, downloaded SPRecovery and clockwork mod. and all the frilly goodies that i was told i needed. ROM Manager, Titanium Backup.....etc. Ok It took me a few tries (only cuz soomeone left out a step in the instructions) I found them in another forum while fretting and sweating....Ok so i get the last piece of the puzzel and voila' I am now rooted. ok so i played around this last week and finally found some roms i liked. So i went to youtube and searched for how to install roms. lots of info there seemed pretty easy. So I downloaded UD8, Succulent Desire v7.0 AB and Shine.
OK next I extracted them from zips to the correct folder "nandroid" on sd card, i had to add this folder. i made sure i did a back up with rom manager first, then i backed up with titanium my apps and settings and such. ok then i rebooted into recovery mode " 'X' and power button. things were looking good but theres the finicky thing i tried advanced, i tried nandroid, i tried everything i could but it only showed me the backups from SPRecovery, i could not find the others i had downloaded.
So i guess this uberNoob could use some help here guys and gals. what have i done wrong or not done should i have wiped cache, did factory reset or what. I am lost and i am usually a compu geek. (background on me ... i was around when you only had basic, cobalt, pascal, and fortran to work with as i was in highschool at the time. and you still had to set key locations/addresses when building your computer. This was the hey day of the radioshack trs80 (trash80) and model 100 laptop with standard taperecorder to save your work on. ... so any help out there for a newly rooted noob????
