JustCurious2
Hello, i just bought the Flytouch 3 and i connected it with an external harddisk but when i tick teh button "my pad' ,there is no sign of any external harddisk ,what should i do?
it is a 2.5" harddisk and ,yes ,it does make noise ,vibrations ,etc ,also the cable is defenitely good connected
and yes there is also a Udisk1 but not under "My Pad"
also i converted the harddisk to fat32 but the tablet still doesn't recocnise it
Can the USB ports supply enough juice to power a 2.5" drive? Regardless of this you might be better with an external power supply or powered hub...
How big is the external drive as you may run into problems if its larger than 40Gb
By virtue of it being a USB socket, it must comply with the requirements of the USB standard.. that requires it to be able to supply 5 volts +/- 5% @ 500mA for USB 1 & 2 and 5Volts =/- 5% @ 900mA for USB3.
So.. you are starting the MyPad app..without any external disks plugged in it shows two tabs, one 'Local' and one 'SD1' (which is the external tf card). Then, when you plug your external HDD into a USB socket an extra tab should show after a few seconds called 'UDisk1', if you then fit an usb flash drive into the other USB socket it will then open another tab called 'UDisk2'.... is this what happens when you try it?![]()
sorry it lasted so long ,my internet connection is sometimes broke.
no ,my problem is that the tablet recocnises a usb stick but it doesn't recocnise an external harddisk (from 750 GB)
Why is this? FAT32 has a 4GB file size limit but 40GB? My FT3 sees a 120GB 2.5" Fat32 external drive fine
I haven't been able to get anything bigger than 40GB recognised by my Flytouch. This has also been reported by others in this forum and other forums as well.
