Noob question about Nexus S
Chr0sy
I want to buy NEXUS S or NEXUS S 4G, which one do you suggest me to buy? Can you tell me the prices for both of them?
And I don't live in USA, I live in Albania, Europe and I just read that it doesn't have a SIM card slot, is that true? :O I want to buy it without a contract, so I just insert my sim card and enjoy my phone.
If you don't prefer this two, can you suggest me other android phones from $100 to $350 ?
Thanks.
you can pretty much buy an AT&T samsung phone or any phone from AT&T and be able to replace the sim card with your own
As far as I know the Nexus S 4G is Sprint only (as in CDMA, won't work on GSM networks). As VoidedSaint said, go with the AT&T branded one.
Or depending on the frequencies your carrier uses you might want to buy a T-Mobile version.
Both the AT&T and T-Mobile versions are GSM. But like the post above me, the Sprint version is CDMA and won't work for you.
