noob question
I just upgraded from the Triumph to the EVO, so far I love it! It is screaming fast!
Question, will the extra charging cables I have from the Triumph charge the EVO? The plug is the same, but I don't want to chance it.
Thanks!
Bucky
Just a tip: make sure any charger you plug those cables into can output at least 1 A of current, or your phone may not be able to maintain a charge if you're using it heavily i.e. GPS navigation.
Good point, metal! The charger I was using with my Triumph was only 850 mA and could not charge my Evo if I was using it (even just for web browsing and texting.) I think the large screen, along with the dual core CPU, make this phone power hungry.
This is why it takes forever to charge the phone from usb, by standard usb ports are limited to supplying 500 ma.
