Markhypnos
Hi
Had my desire for a few months now, really loving the phone but the low memory issue is really becoming a problem now. Ive tried the unrooted method but it only saved me 20-30mb of space.
So ive decided im to take the plunge, ive read through quite a few threads on here to get an idea and have some questions. Hopefully having the info I need in 1 thread will help as well. Thanks for any help it really will be appriciated.
1) Backing up, which is better titanium backup or mybackp pro? will these backup and restore settings apps between roms? I have mybackup pro but it only seems to have 50mb online storage. Does appbrain allow me to easily redownload apps on a newly flashed rom?
2) If I change my mind about going back to stock unrooted is it easy enough to do and where/how can I do it? (Im vodafone UK branded 2.2) and does this replace the recovery with the original too?
3) Goldcard? I presume this is only need if I want to update software on a branded unrooted phone?
4) Protected apps, will I have a problem here or does it depend on the rom? Also do all the google apps need to be downloaded from the market now?
5) Roms, i've decided I want to try defrost as a vanilla rom, any suggestions for a basic sense rom with a2sd+. Do I have to flash roms from my pc or can I store them on my sd and flash from there. Id prefferably rather not flash a new radio as id rather not brick my phone.
Thats all I can think of at the moment, thanks
