nor problem nstalling zip files from sd card
Ranger0001
I am trying to install the CM10 mod to my DroidX2. When I goto install zip files from my SD card, It jumps ahead the next screen "-META-INF/....-system/" I must be doing something wrong, just dont know what. Did I download the wrong file?
Welcome to AF!!!
CM 10 is a ROM, you have to flash it using a custom recovery. I can't really help you with instructions on how to do that on the X2 since I don't own it. I can however sugest that you check out the forum that Rush suggested. You will probably find all the answers you need there.
Welcome to AF! Hope you enjoy your stay here. :ciao:
Just as urge stated above, you need a custom recovery to be able to flash a Rom, impossible to do it within the system while booted up.
DS
