Maskills24
Hello guys, just got my phone back to a factory state and was testing out some of the apps to make sure everything was working as it should, i found my self at the message app and everying was working fine, then i went into setting to see if everything was there, but under the background settings i was not able to switch the background to a custom image.
Here you can see where the tile that would let you select a background from your picture library is no longer here, i know for a fact that my friend that has the s3 and is using touchwiz as well has the ability to do so. Not sure if this feature is a special version of the app only for galaxy S phones or only for JB, since the s3 has a jb update now. Suggestions anyone? Thanks.
