Help Not Able to Login in Android Market
hi PPl,
i am not able to login in android Market , i am getting Error as
"Can't Establish a reliable data Connection to server "
But i am able to Browse thorough Browser.
i am having Xperia X8 E15i
Thanks & Regards,
Sabari
hi PPl,
Thanks & Regards,
Sabari
try a battery pull with the phone on,or uninstalling the updates on the market clear cache,data or force close the android market app
make another gmail account, turn wifi on and see if that works
This is generally caused by one of two things, either you are using WAP settings from your network and not Internet settings or you may have a bit of a software problem.
To check the settings : Main Menu > Settings > Wireless & Networks > Mobile Networks > Access Point names > Check with you network that what you have here are Internet access point names and not for WAP.
If you have the correct settings then please try the steps outline above by ZeroOne and if the problem persists, run a software update:
http://www-support-downloads.sonymobile.com/Software Downloads/Update_Service_Setup-2.11.12.5.exe
