Root Not Able To Root ZVD
Hold both volume buttons when you boot and then hit the power button at the reset screen until it loads.
Doesnt let me.
EDIT: Nvm, I'll download CWM via ROM Manager. Little problem though, It tells me "could not be downloaded due to an error" is that because is not google play yet?
well assuming you were able to root your phone finally did you install clockwork mod? if so you could download off the androidmarket rom tools that will install it for you. or was it rom manager? damn i cant remember maybe some1 else can verify it.
Update from ZVB to ZVD as well.
Did a factory reset.
Loaded drivers.
Connected with USB debugging enabled and internet connection
When i run the root file it says
"ABD is not recognized as an internal or external command operable program or batch file"
Completed enjoy root.
Then i check with Rom Manager says im not rooted!
Help please.
Loaded drivers.
Help please.
this is the only root that is working for zvd
http://dl.dropbox.com/u/42472659/LG_Esteem_Root_v2_Windows.zip
