Hi
I have an Ace II and it's probably around a year since I bought it.
At the moment I'm having some trouble getting it to start, and I'm not why, but I suspect it is simply not charging as the problem started when it's battery charge ran out.
It's definitely not the charger itself as it charges other phones fine, and I cannot charge my phone with any charger.
Once I hold down the power button to turn it on (while it is plugged into the wall charger), it does a small vibrate, the start screen comes on, and then it shuts down again. Same thing happens when I start in manual mode (Home + Power + Vol Up).
Any advice would be greatly appreciated, and although I had a search around the forums for people with similar problems, I couldn't find anything so if you find a thread like this one it would be great if you could link me to it.
Thanks.
EDIT: Phone is fixed now. I simply cleaned the charging port with a toothpick and got rid of all the crap in there.
Thanks.
