deedee.1984
Hi all.. I'm on o2 (UK).. After patiently waiting for the 2.2 Froyo update , I finally downloaded this morning via "check for updates".. Unfortunately I did not have enough memory space and had to cancel the install. I then went through my apps and uninstalled them so that I'd have enough memory space. However, the install has not restarted. I have tried restarting the phone and also checking for update again. The update zip file is sitting on my phone but I havent a clue how to restart the installation.. please help!! This is very frustrating?!?!
Thanks!!
Thanks!!
You'll lose all your contacts/calendar/apps (back-up first - and make sure it works). It's effectively a factory reset but it works and it's controlled over the USB by the PC so it's fairly "safe"*.
