Help not provisioned for data services
How do i get into the market on my gmail account because it keep saying im not connected to a server or its not provisioned for data services or sumthing i need help !
Can you get online other places. Like if you open the Browser does it load or does it tell you cannot connect or something. If you can't connect with Browser either try Going into Wireless & Networks, Check Airplane Mode, leave it like that for a few seconds, then Uncheck it.
If you can connect with other apps such as the browser then I think maybe its on Google's end. Last night Phandroid News reported that Android Developers were having trouble accessing their Developer accounts. I know your not a developer but they may be experiencing problems in general.
Here is the link to the article:
http://phandroid.com/2011/04/03/android-developers-having-issues-updating-their-apps/
WOW after 2hrs on the phone with verizon wireless...I FINALLY HUNG UP AND FIGURED IT OUT MYSELF>>>>>>>>>>PRETTY SAD I KNOW MORE THAN VERIZON>>>>I KEPT GETTING THIS ERROR AFTER THEY HAD ME SIGN INTO MY GOOGLE ACCT 8X ridiculous......heres the solution besides throwing your phone out the window.....
GO TO YOUR SETTINGS BUTTON
GO TO ACCESSIBILITY MAKE SURE THATS CKD
THEN GO BACK
PRIVACY MAKE SURE BOTH BOXES R CKD
THEN GO BACK
ACCTS N SYNC MAKE SURE BOTH BOXES R CKD AND UR GOOGLE ACCT SHOWS UP, AT BOTTOM
THEN GO BACK
WIRELESS N NETWORKS SCROLL DOWN TO BOTTOM CLICK MOBILE NETWORKS CK DATA ENABLED
THEN UR DONE TRY GOING BACK INTO ANDROID MARKET IF IT DOESNT LET YOU TURN PHONE OFF TAKE BATTERY OUT AND RESTART....
WORKED FOR ME AFTER I GAVE UP ON VERIZON FOR 2HRS.....
IF THIS DOESNT WORK YOUR ONLY LAST CHOICE IS TO GO ON ANDROID ACCT THRU UR INTERNET....
GOOD LUCK.....WHAT A PAIN IT WAS.....HAPPY ITS FINALLY FIXED!!!!!
Sorry Im Facing The Same problem as you but i cant uite understand what ur trying to say by listing down the steps?and what is ckd,u mention that alot but i have no idea wats tat.
Olivia2011
Im facing the same problem as you but can u pls specify more and list down the steps,and wat is ckd,u mention it alot but i have no idea wat is tat.
THEN GO BACK
THEN GO BACK
THEN GO BACK
Sorry I Dun Understand The Solution Ur Talking Bout,can u kindly pls be more specific and list down the steps,and wat is ckd,u mention it alot but i have no idea wats tat,i been having this problems these past few days and really nid help on it
