It's most likely them, an Apple thing. iMessage is kicking in and that kicks you out of the conversation. It happens to me all the time with my family because they have yet to fix their settings.
Try using a different text app, I'm currently using Hangouts, it works well. I've had good luck with Textra and Chomp too (same developer). Whatever you use be sure to check settings, I have mine set to use 'group messaging', it flips it to MMS for groups. That seems to help. Somewhat.
Also, have your iPhone friends check their settings. They want to enable MMS and group messaging.
I keep telling my family green (SMS/MMS) is good, blue (iMessage) is bad. They just don't get that. Ugh. I've even tried to get them to use Whatsapp for family texts, that's way too much for them to comprehend though.
Good luck! This may just be a regular source of frustration for you...and it's them!
