Root Not receiving text messages
idreyn
Perhaps this is beyond the purview of those in this forum, but I figured I'd check. I have not been receiving any text messages whatsoever over the past 48 hours...sending them, calls, and data work just fine. This happened first on g60's CM10 but I've flashed the Midnight and PA zips I had lying around and neither is helpful. I called Virgin and they directed me to a ## activation menu that of course doesn't work on my non-stock ROM.
I guess I'm wondering whether this strikes anyone as a radio issue (never flashed a radio update) or a carrier issue. I'm worried I screwed up my phone permanently but I can also see Virgin finding a mistake on their end. I'm going to RUU back to JMZ stock as soon as I get a chance unless anyone can suggest something I should try first. Thanks!
A lot of roms come with custom dialers but if it's a Sense based rom the dialer codes usually work if you go into the app drawer and choosing the stock phone dialer there. Also are you able to send yourself texts?
I installed Harmonia with the intention of trying the dialer codes with that, but it actually seemed to fix the problem! I got 31 text messages quite suddenly. I wonder if it was a radio update that came with Harmonia, and I'm hoping I can migrate back to an AOSP rom soon.
Thanks for your insight!
