Not receving calls
jason504504
I am on jellyverse and a couple of days ago I have noticed that I am not receiving all my phone calls my girlfriend sat here and called me in the same room and my phone never rung I can call her and it was fine I get text but wtf
I would check the data toggle, sometimes it gets turned off, its happened to me a few times...........
What's your Baseband say in Settings/About Device?
When you call your phone, does it go straight to voicemail or does the caller get ringing?
I even went back to stock and it still does not work everything else is working text I can call out but not receive a call I am lost dont know what to do
Then try doing a SCRTN reset while on factory stock If you still can't get calls then the problem may be on the company side with your account, and at that point you will have to contact Boost.
You do need to be on a TW ROM that has the hidden menu function it should work for that ROM, Otherwise, flash stock then do it.
It did not work but I found this out when I am not at home it works when I am at home it does not work weird I don't get it
