Not recognizing when I type
Hypo Luxa
I have this intermittent problem where I'll go to answer a text message or do a Google search and I hit the window to open a text box and then the keyboard pops up and I go to type, and it shows the keys i hit, but nothing comes up in the text box. The text box doesn't have the focus. I usually have to get out of the app several times and go back in and keep trying till it decides to eventually work.
Google is the worst when it happens because I'll have to close and retry prolly 15-20 times before I just give up. I had this before and I did a factory reset and it seemed to go away, then I rooted and went with Evil Eris 3, and after 1 or 2 weeks, it popped back up again Saturday.
Anyone else have this issue or hear how to fix it? it is quite frustrating
The only time I have experienced this problem is when I had Widget Locker installed on my phone. If you have this app I would uninstall until they get the problem worked out.
hmmm, I don't believe I ever had that one installed.
I'm not saying you do, I'm just relaying my experience just in case. Like I said that is the only time I've experienced this problem. I'm sorry that you're running into this problem. It still could be an app but it will be a pain trying to figure which one.
Yeah.. especially since I can't pinpoint when exactly it started and I can't predict when it will occur again.. oh the joys of technology..
I have the same problem and like you im totally stuck. ive had the problem for the longest but i have noticed that since i did a hard reset that the problem doesnt really happen anymore. and i also use better keyboard. becuase what i noticed is that if you switch keyboard sometimes it helps that way you dont have to switch out of you app that you are in.
my suggestion, do a hard reset and install each app you have now again one at a time.
then try to pay attention to the one you install right before the problem occurs again.
it worked for me granted i dont know which keyboard or app it was but i know now that i dont have that problem and love my phone. *cheese*
