Hi.,..I am more than fed up with this phone..I have samsung galaxy skyrocket ll
When I first purchased this phone 4 months ago an error occured that required a new phone be sent. It is a new phone from the factory. The second phone throws me the following error message MOBILE NETWORK NOT AVAILABLE quite frequently. It happens at any location, in the middle of calls causing it to disconnect, when sitting idle...the solution is to pull the battery and sim and then reinsert and reboot. Often I have to do that 3 or 4 times in a row before I get back on the network. Last night it happened and this time nothing helped...rebooting, reinserting SIM...I checked the SIM on a retired LG Neon and it is working just fine. Next I checked for firmware updates and found one I hadn't done, so I downloaded and installed. The phone is now showing im on a network but now the error message reads NOT REGISTERED ON NETWORK. I looked for solutions online and found that most required going into the mobile networks setting to add an apn etc...but when I try to go to mobile networks it says INSERT SIM TO ACCESS MOBILE NETWORK SERVICES. Can anyone help..I really am grateful for your time reading this...
This is my first android and it's been a horrible erxperience. Juls
