Help Not ringing!
DamoM
My one x has developed a problem whereby it only rings occasionally when there is an incoming call, despite the volume being set high. I cannot see any rhyme nor reason for this.
I've removed recent software incase that was having an impact but it is still doing it.
I can call the phone from another phone right in front of me and it will ring. I can hang up, try again and it won't??
Was wondering if anyone else had had any experience of this?
I'm running android v4.04 and Sense v4.1.
Help! :confused:
Welcome to the forum DamoM :)
Coudl I just ask a few questions..
When you ring yourself the 2nd time and it didnt work did it still show up on the screen that you had an incoming call?
Also do you have a custom mp3 as your ringtone or a stock ringtone from HTC?
Cheers
Cheers
Hi Jimbob. Thanks!
yes the 2nd ring shows up as an incoming call with my contact details, picture etc.
I've tried it on a stock ringtone and it makes no difference.
under settings>sound, do you have "pocket mode" or "quiet ring on pickup" turned on? if so, maybe try turning those off and see if you still have the issue?
I've tried everything but it's still not working. Getting to the point that I'm going to have to do a reset. :confused:
Were you ever able to get this fixed? Im having the same issue where I can see the call come in but it just wont ring??? Its really strange because it was ringing but now its not...
It sorted itself out with the update (to ICS I think). Sorry I couldn't be of any more help. Hope you sort it.
I have this issue also. No ringing and no missed call indicator at the top left. This phone has all kinds of bugs... The most I have ever seen on an HTC, and this my 3rd android HTC device.
