Help Not saving SMTP authentication settings
z4cz0r
Android Version: 2.2
Network: Vodafone New Zealand
Taskiller Used?: Advanced Task Killer
[Optional]Are You rooted & which Rom: no idea!
Issue: My phone doesn't seem to save the SMTP authentication settings. I use Xnet for my incoming mail and Vodafone for outgoing. I do not need authentication on my outgoing mail, and every time I change the settings, the check box for "Server requires authentication" is checked, I then uncheck it, save the settings and try and send email. It doesn't work, and upon going back into the account setup, the bloody "server requires authentication" box is bloody checked!
I have had a look around and can't find any info, hoping you can help
Incoming mail works fine, only an issue with outgoing
Cheers
Zac
