It is estamating as if you continue to use your phone how you have been. Takes a few days to get accurate. Changing how you use it will change the estamate.
It is guess-timating as if you continue to use your phone how you have been. Takes a few days to get accurate. Changing how you use it will change the guess-timate.
Accuracy has been bad after the recent round of updates.
No kidding! I've been using it for months, and two times today it jumped into "ESTIMATING" mode. Then next time I looked, it was "ACCURATE". Both times I had to re-set up what I wanted the type to say.
The fact that your phone was idle is exactly the situation where the estimate is most likely to be grossly off. This is because it is estimating based on your past usage, not on how you are currently using the phone. If you teeter to one of the extremes (idle for a long time, or using it constantly for a long period of time) it will still continue to estimate based on past usage, but it will add the current usage as new data to use for future estimates. The thread on droidforums has a much better explanation from the dev than my screw job right now.Yeah I know, but at that moment the phone was idle and had been.. just found it funny
