Not using the battery door...
tpXXV
while using a case like the Incipio Feather in its place. Is this a terrible idea? Obviously the concern would be exposing the internals to dust/particles.
The goal is to be able to use the extended battery, but I like the matte finish of the Incipio or Case Mate Barely There. Neither of those fit ideally with the extended battery door. Not to mention you cut down on thickness/weight if you remove the door.
Thanks in advance.
Thanks in advance.
I think it'd be OK as long as you still covered it with something and as long as knew the risk. What that something is idk, but you'd need to make sure it'll hold the battery firm in case it jostles loose. Tape of some sort, a kind that will leave no residue and able to be removed easily? Painters tape?
i've been using my incipio case that i got at VZW with the ext battery and the door on it. Your right it doesn't fit 100% right but to me i'm fine with the way it fits.
I went my last couple of months with my Droid 1 with no battery cover and had no problems.
rain was pouring down one evening and I ran to my car from the grocery store and my Droid flew out of my pants and I grabbed my phone and battery (which fell out) but forgot the cover.
Anyways one nice advantage was it was very easy to do a battery pull for all those times my Droid locked up.
I am not using the battery door with extended battery and otterbox defender case.
I tried it with the extended battery door and it felt like a bit of a tight squeeze. I tried the stock door with the extended battery and it wouldn't close right at all. Without the battery door, the extended battery fits in the otterbox just like the regular battery did with door: that is, a bit loose and the case is easy to put on and off. Even though it feels a little loose in there, I've jostled it around pretty hard and the battery will not disconnect from the phone. The hard case layer has a soft lining that seems like it is as good if not better than the stock door.
With a case like Otterbox it might be alright, but with other cases I think you're inviting moisture into the phone. Even condensation from a shower might be enough to screw up the phone.
