Help Not vibrating when I get a text message
When I set my phone to vibrate, it will only vibrate when I get a phone call, not when I get a text or email. I saw some solutions for the Droid, but not the Droid X. I am not sure if the solutions are the same. Also, when it is on ring, it rings and vibrates, not just rings. Any suggestions? My main concern it getting it to vibrate when I get messages, I am not too concerned about the ring/vibrate thing.
Thank you so much!
Cari
Thank you so much!
Cari
#1 - go into Text Messaging App, hit the options button (left one with little squares). You will see Messaging settings, there you will see Text Messaging settings, look for Vibrate. Should work now.
#2 - The vibrate you have enabled in the sounds settings is for the phone to vibrate when you receive a call. So you thought you were activating what you needed but in reality you were just enabling what you don't want the device to do. :D
To me that doesn't make sense, I don't always want my text messages to Vibrate but I should be able to put the phone in Vibrate mode so that calls,text messages etc.. vibrate instead of going into the text message application.
