Help Note 10.1 to tv using s3 & tab peripherals
S
slobbythegreat
Guest
So, and I have movies etc on my 10.1 my question is can be I plug the note into the TV then access my note using my s3 as a type of remote to pause next etc???
Also are the tab and note pin connectors the same? I can I put a note in a tab desk stand and will oem tab cases fit the note???
No.
Yes
Possibly. The connector is the same but the Galaxy Note 10.1 and the Galaxy 10 inch Tabs have different dimensions. So if the Desk stand "grips" the tablet then it probably won't fit.
No.
No
Faaark
Yes
Yewww
Hmmmm
No.
Faaaark
Thanks for the help
