Note 2 case face off. Otterbox vs Samsung
Fr0stTr0n
Allight, like alot of you Note 2 owners, your Note 2 is your preeeeeeciousssssss :D Seriously, well no, seriously, it is OUR precious indeed and I personally like to take care of my expensive electronic toys to prevent mishappenings and expensive replacements.
Ergo, I learned this the hard and expensive way of being a total dumbass and ruining my beloved Note 1 back in October by taking it into the bathtub with me to websurb. Low and behold, I lost my grip on it and "splash" it went and in within 2 seconds, my Note 1 just wasn't the same anymore. Yeah, I had insurance with Asurion but honestly, who in the hell would wanna pay a $200 deductible for a refurbished Note 1 with the Note 2 out?
In any case, two weeks ago I managed to get a "Exception upgrade" through a local AT&T rep at store and got my second lovely new Marble White Note 2 after the first one had stuck pixels on it.
In any case, like alot of you, I went through and spend hours here and on web all around trying to decide what case to protect my beauty from the harshness that is gravity as well as typical daily use. I knew I would like the Otterbox Commuter from my last experience with Otter on my Droid X but the Samsung Case + also looked very nice, so being me, I bought both and finally got the Case + today to compare them side by side and here are my thoughts.
The Samsung Case + does look rather streamlined in comparison to the Commuter. Its not as bulky as the Commuter in comparison and doesn't increase the general phone size if your preference is to keep size and weight down. However, the first trade off is that because of the design, the Case + isn't as easy to grip as the Commuter thanks to it ribbed back, and larger amounts of silicon rubber to hold onto. Again, this will be down to preference but for me, the commuter is easier to hold onto by far.
The Case + will protect from slight dings, nicks, scratchs and banging your phone around in your pocket and accidently walking into walls, chairs ect.... The full wrap around of the Case + will assure that your your Note 2 will be generally protected and the fact that the buttons are covered to prevent debris from entering is also a nice bonus
Whats obvious from the start is that the Commuter is designed to take the punishment of any impact vs the Case +. The polycarbonate shell is essentially unbreakable by design and is nearly twice the thickness of the Case +. Along with the silicon body glove, the Note 2 is protected by nearly 4 mm's of case as you can see by the pen opening. I also found that the Case + causes the speaker output to lay flat on the table, allowing the speaker to be muffled where as the Commuter has a slight raised edge on the speaker hole, allowing it to function without a problem.
However, its easy to see the Commuter is designed with more protection from abuse in mind vs the Case +. The silicon rubber glove will help absorb shock and impact all around the phone were the Case + is pretty much just another layer of plastic.
Looking closely, you can see on the corners of the Commuters silicon glove there are "sectioned off" looking compartments. These are designed to help absorb the heavy shock from being dropped onto a hard surface on the corners of the phone. Again, the Case + basically has some semi flexible silicon on the edges but hardy enough to absorb the jerk that is gravity in carrying your phone to its death onto concrete
One thing I was surprised to find was that the Case + actually has a tassle loop on the upper left corner if you really wanted to "tassle carry" your Note 2. I dunno about you, but there is no way I would try to carry a phone as big and heavy as the Note 2 with nothing but the case clinging onto it with a tassle and though the Case + snaps on pretty firmly, I wouldn't trust it with my Note 2's life. Though it has to be said the buttons on the Case + are easier to push then the Commuters for obvious reasons
Another big difference is that the Commuter gives your Note 2 a good 3mm of screen saving space as a result of the body glove. This will ensure it will be very difficult for your Note 2's lovely screen to meet any sort of surface sans hitting a rock or very uneven surface like gravel or rock pit.
The Case + however barely gives you around 1mm of clearance on the screen when layed flat and because the semi flexible rubber on the Case + isn't very thick let alone shock absorbing, there as much better chance your Note 2's beautiful screen won't survive a hard smack on the surface beyond a cushy carpeted fall.
Another big difference between the cases is that the Commuter has nice big flaps to protect the headphone and charging ports when not in use. People who have carried phones in their pockets are full aware of how much dirt and crap can get stuck in those ports from previous experience on other phones that basically requires a toothbrush or compressed air to clean out. The flaps stay firmly in place against the hard shell with small built in tabs and because the silicon is rather slippery, the covers do not open very easily by accident.
All being said in done, its gonna be be up to your personal choice of what case fits your needs and usage of your Note 2. The smaller Case + might be a better choice for those who are small handed and or are extremely careful with their phones all around or carry their Note 2 in purses or handbags and such. It also does look sleeker if your more into the presentation of your $700 phone and just want basic protection to protect from every day usage vs having the phone naked and vulnerable.
The Commuter is much more ready to protect your $700 investment from the rigors of being dropped, mishandled and in general, saving you from the shock, misery and sadness of seeing your phone smashed to bits on the cold concrete.
That being said, the Commuter makes it easier for me to hold the phone and gives me a more comfortable and safe feeling in protecting my new beloved Note 2, so its Otterbox for this Note 2 owner.
I got an Otterbox Defender for mine and Im extremely happy with it.
Cant wait till the first time I drop my phone so I can see how well it does lol!
J/K I hope I never drop it!
My 9 month old daughter likes playing "my baby fireworks", once she gets bored the phone gets thrown, my commuter is serving me very well :-)
I'm gonna try out this urban armor gear case when it's released..I'll report back on what i think of it
I really like my OB Commuter case. It gives me a sense of security and I really like the way it makes the phone feel in my hand. The Commuter is obviously a quality made product. And honestly, this is a giant phone to begin with, a few more mm isn't a deal breaker if you've already accepted its size. A slightly larger phone is a small price to pay for the protection it offers. I have no regrets with mine.
Good write up Fr0st!
Can you please comment on how slippery one case is in comparison to the other? I'm sure you are used to it by now, but my first impression while handling Commuter on my phone in the store was that it felt a little slippery in my hand and when you put it down on the table. I heard Samsung Case+ back is almost as bad as the original phone battery cover, the only grip is rubber bumper. I can't comment on that since I never had it in my hands. So, a comparison would be great!
+1 anxiously waiting for this one as well. The last I heard another 2-3 wk wait to order it. Apparently they didn't anticipate such a high demand. At the same time, a lot of people who have their iPhone/SG3 cases commenting they don't like a new design with a back insert to change color. I'm just happy it has a different look to make the phone stand out, but the most important thing I will need to find out about is the level of protection. That is one requirement above all others. Ballistic cases have a thicker corner padding, this one is not as much, but it supposed to have a better material to absorb more shock. OK, lets continue UAG discussion in general case forum, so we don't hijack OP thread :)
The Case + is even slipperier as it doesn't have the texture surface like the Commuters poly shell does and the hard rubber on the edges only helps so much, so its worse in comparison.
I'm actually really happy with my cheapo gel case from ebay. Single Gel wrap, like the commuter inner, with the minimum of fuss, size and weight.
I do like the gel cases but having the screen uncovered is always something i dislike, personally i have bought the "flip cover" i think it's called? It covers the screen and is a backing to your phone so if it breaks you can always replace with your old one...Anyone using this? and while im on the subject is there any word on a front and back leather case like the wallet styles?
There are tons of wallet style leather (or fake leather) cases on Amazon and eBay. With a flip cover, a lot of people do use it, but it's not the cover you should be worrying about breaking but rather phone dropping and flip cover offering no protection to absorb the shock. I think most of the people get flip case to protect the screen from scratches and make the case a little less slippery. Plus its slim and you have different color choices.
ive had trouble with the seido case i have with the earphone not being all the way in and disconnection issues. the ob is great case compared to it. has anyone put the screen protector on that came with the commuter.. i tried to but it doesnt fit the whole screen and i messed it up putting it on.
I have both the Commuter and the Samsung case as well. I got the black and the pink one. I got the black to modify so that I can use a flip cover with it was well.
I agree though, coming from using the Commuter, the "protection" that the Samsung case offers is worrisome for me. Though I do like how it keeps the integrity of the original design of the phone (slimness, etc).
I think it may only protect the phone from scratches to the body - but not sure how much other protection it offers.
Had the Defender for 2 weeks. Protects the heck out of the device, but at the end it us just too bulky. I like a blet clip, but this thing pulls your pants down...too big. I contacted Otterbox and explained the problems that I was having with the oily spot and wet spot and they are sending me a commuter.
Sent the Defender back today. (I have owned no less than 5 Otterboxes and the Defender is by far the best protection out there, but on this phone just makes it very hard to fit in a pocket or on the clip.
These are my power cases....I also want the commuter but for now this is what I trust the most.
Defender and sedio active and both saved my phone face down drops on my tile..
My tpu case from Sammy it shattered.... Now I don't trust tpu at all.....
