Help Note 2 spreadsheet and keyboard.
marsheng
The note is a great working tool and the stylus is the best. I use the phone for spreadsheets, however the Samsung on screen Keyboard takes up half the screen. Smart Keyboard Pro is a good alternative as you can shrink the size down giving more spread sheet view.
Is there anything better?
Is there a quick way to toggle between the Smart and Samsung keyboards ? I prefer the Samsung KB on some apps.
Another option is to use the hand writing mode (great as I don't need to press 3 buttons for an = sign) but the hand writing area is huge. I would like it to be 1/2 it's size.
Thanks Wallace
Whenever you have any keyboard open there will be input method item in the notification drop down which allows you to quickly change your input method.
There is a option to change the current keyboard settings but not the keyboard itself.
When you pull down the drop down menu there is a keyboard icon and will say "Choose input method" where you can change keyboards.
Edit: your keyboard should be up.
Sent using the force
Where is the dropdown ?
If you are talking about the main page dropdown with GPS WIFi Mobile data Sound etc, I can change the settings there but that is about 10 keystrokes and gestures to do what I want.
I'm looking for a 2 stroke/tap change.
Its below the wifi, bt, sync, etc. Just above the notifications and "clear" button
Thanks Caloy.
Ok We are getting somewhere. I don't have the keyboard option listed under OnGoing. How do I get it listed up there ?
Make sure your keyboard is showing when you pull down the notification bar. :)
When you tap on it you'll get this:
Coming from iPhone 4 spreadsheets (Numbers and Calc Lite), I kinda like Note 2's overall functionality on spreadsheets (Polaris). I like the stylus (S Pen) and it brings me back to my Palm PDA days. I use the stylus a lot than the finger keyboard. I'm a number cruncher and Note 2 stylus functionality enhances my productivity. And on account of this, I purchased spare S Pens.
