Hi
I have a 16gb Note 2 (loooove it!) and a 32gb mem card.
Ive noticed my phone space is under 500mb now and I want to make apps auto save on the memory card or even move them over to it.
Is there a way to move apps to mem card?
I have like 28gb spare on the card
Thanks
Hello OneZeoN.
If your device is rooted, there are several reliable apps for the purpose of moving and/or installing on the removable sd memory card. However, stock devices designed by Google/Android after the "4" version of the OS will for the most part use only internal storage for most apps and widgets, etc.
Here is their reasoning, as quoted from Samsun Support (not a carrier store floor monkey, an actual tech level support person):
"Thank you for contacting Samsung Customer Support.
I’m sorry you are having issues moving your apps to SD card. I can understand your frustration as it is good for freeing up memory on the tablet or phone.
Please note that moving or installing apps to external storage is no longer available on any Android from version 4.0 and above, due to how the Android operating system reads storage on our devices.
The Android OS now operates on a unified storage system from Ice Cream Sandwich onward, meaning it will read one data partition for storage, rather than two.
The reason why previous Android versions had the capability of moving apps to external storage was because the phones memory was split into two partitions, one for external storage and one for internal.
Now, with Android using a unified storage system, all applications will be stored completely on the internal memory of the phone. This allows for around 11GB of storage space on a 16GB device for apps. Google, the developer of Android, feels this is more than enough for users, as their operating system was designed for use on their own phones as well, which do not have any external storage at all.
Please also note that we do not advertise any of our devices as having the capability of running or installing apps directly onto the external memory card. You will have to install your apps to the internal memory, but anything else (music, videos, documents etc.) can be stored on your external memory card."
