HI,
I have a few issues I am hoping someone can help me with. First though as I have been looking around for help online, I have noticed any directions have been different on my phone even though it is help for my phone I am looking at. I think it is because my phone has been upgraded to android 4.4.2. and most instructions are for older versions.
I have a Note 2 , Model # SGH-T889V, Android version 4.4.2
1. Does this Android version mean the software(firmware?) is KitKat??
2. Every time I take my battery out, I lose my wifi network key and have to keep entering it to connect. I took it to a shop (Cell Doctor, Calgary, Alberta) where I have some repair warranty and they did not know if this was normal. they gave me a 1-800 number for Samsung and sent me looking for a payphone, though I was already certain it was normal like a computer and that was confirmed by a friendlier Samsung rep. I went back and educated the two youngin techs at CellDoctor and one took the phone and frigged with a setting and that worked for a while. They said all I had to do was click the "remember keyword" setting where I inserted the wifi network key. I can't find that anywhere.
Can anybody direct me to that setting on my version 4.4.2?? Please.
3. I have also been told that I cannot use the GPS navigator, giving me directions unless I have a data plan or wifi. When I am driving I have neither. I set the destination when I do have wifi at home and it gives me really good voice commands until I arrive but changing a destination again with no wifi does not work. It gives me an error of no wifi connection. A stand alone GPS you buy for a car, has no wifi or data plan and it works with 12 volts and a GPS signal. Should not my phone act the same???
4. My battery worked really, really good. I started using APPs such as battery doctor and battery drain and now when I use this battery, it makes the phone reset, go through booting, over and over and over again. A new battery I just bought works well. It seems these things are really fragile compared to a laptop. Should I be really carful about which APPs I play with??
This is my first smart phone and it has been really, really frustrating to say the least.
I hope someone can help me out with these issues.
I look forward to your help,
Antonio
Antonio
