Help Note 3 a d my Sim Card?
Hi everybody. So I ended up breaking my Note 3, and getting a new refurbished one from best buy using their insurance. So basically if you don't know how it works, best buy only gives you the refurbed phone (No new s pen, battery) So i had to use everything from my last phone, including my old sim. The sim card was giving the guy trouble, and he ended up having to pry it out in the back room. So I get my phone set up and activated through sprint (unfortunately), and it takes a little more effort than what it seems like it should. But everything was good for a little while until I got home. It seems that there is something wrong with the sim card or something, because after 5 minutes that the phone is started up, the self service setting pops up and says "because of the type of account you have, we'll need to help you with this task" (picture 1). I can exit and nothing happens. Then maybe 10 minutes later, I get a popup that says "sim card has been removed" or something stupid like that (picture 2). I called Sprint and some guy said go get a new sim. I still have all my services (texting, calling, data) when this happens, it is just the stupid notification wont go away saying sim card removed. Is this all from my phone or my sim card?
Easiest way to find out - go to a Sprint store and have them replace the SIM card. If the phone is defective, bring it back to Best Buy and ask them to try again.
