I bought an OTG cable for note 3, I was able to connect my mouse and it work but when I try connect my WD my passport hard drive to it, it said unable to recognize drive. Does any able successfully connect usb external drive to note 3 ?
I connect USB flash drives regularly and they just work, so I can't really help you. Are you using an original Samsung OTG adaptor? Some are weird differently I believe.
I bought it on ebay for $5.
Not necessarily. The file format it is in will also be a factor in whether or not it will work. Android does not have native NTFS file support. Also you cannot format a high capacity HDD to FAT32 unless you use other means.Format a USB stick to FAT32 on your PC and if it works with your adaptor it should be OK for external hard drive with its own power source.
