Note 3 help!!
Whenever I return to my homescreen, whether I have just unlocked my phone or have pressed the home button after using an app, my wallpaper moves from left to right. It seems it has to calibrate or something, it does it instantly but is really starting to bug me. Its like the wallpaper is glitching, I've tried everything I know to try and fix it but had no luck, please help.
Much as I hate to say it, a factory reset may fix this issue. I just had to do one myself because the Google Play video player just wouldn't work right. I suspect something became corrupted. Anyway, the reset worked even if it was a pain the behind.
Are you using a custom rom or rooted phone with customizations? Which launcher are you using?
