Note 3 restart loop problem
ahmedphil
Hello all
i purchased a note 3 on May while i was in a business trip in Dubai , i bought it from a website as a refurbished so there is only 3 days warranty on it , after taking it i tested it without SIM and it was running well , after i came back to Jordan (my country) and inserted my SIM card , the problems starts its randomly restarting while the SIM inside , some times it restarts every single minute and sometimes every 2-3 hours , the current software version is 4.4.2 with the latest updates from Samsung ,Im listing below what solutions I've tried with no luck till now at all .
*factory reset
* wipe cache partition
*disabled auto Sync
*disabled WIFI always scanning
*disabled Samsung pre-installed applications
*replaced SIM card from my carrier
*did the latest updates
*used a software to fill all the device memory and deleted it again
*installed new 4.4.2 image
*tried another battery
please note that the device is working perfectly without SIM with almost no restarts . usually after doing factory reset (which i did so many times)it starts to give "unfortunately process has stopped" messages immediately after finish the reset . this message appears almost for most of applications running then the restart loop starting again .
i took the device to the local Samsung dealer and after checking it they said the the device needs replacement for the board + charging base which will cost JD275 ( arround $390 , which is too much comparing to its current price ,
I'm wondering if its possible for a device to run in that smooth without SIM to be really in need for this much of major maintenance work!!!
any suggestions ?
many thanks
