Here's a pretty cool video review of the S-Pen functions...
I stopped by Best Buy for ten minutes yesterday. Had a 1000 mile multi-state drive to get back home, but still couldn't help myself stopping at Best Buy to see and hold the phone. Wow. Talk about an improvement over my N4. Cannot wait until I have this thing. Anxiously waiting for my preorder shipping email to hit....
I have to admit, I was initially concerned about the dual edge display, just from my experience with the Priv (and to a certain degree, the Note Edge), but once I actually tested it out in store, all those worries went out the window. Only thing I kept thinking was wishing that they'd have offered the option of purchasing a 128gb version in the US.Convinced you enough actually holding it, Teegunn?I have to admit, I was initially concerned about the dual edge display, just from my experience with the Priv (and to a certain degree, the Note Edge), but once I actually tested it out in store, all those worries went out the window. Only thing I kept thinking was wishing that they'd have offered the option of purchasing a 128gb version in the US.
It's funny cuz the Note 4 didn't actually impress me enough to upgrade from the note 3. Then when the Note 5 was released, I was more impressed with the design, but it was a deal breaker not having a micro SD. Holding the Note 7 and comparing to my Mate 8, I almost wished Samsung had bumped up the screen size just because of the ergonomics they pulled off on the 7. Their ability to drop the width by so much, I almost feel like they could have pulled off a 6 inch screen, but still have a phone that matched dimensions (or possibly smaller) than the mate 8, Nexus 6p and iphone 6plus. Overall, I definitely felt like this was the first time in a while that Samsung impressed me.I was already convinced, but actually getting to hold it and compare it side by side with my Note 4 - the Note 7 is a real leap forward. I also wish we had the 128 gb version along with 6gb, the 821 processor and a battery at least as big as the S7 edge, but I guess you can't have everything. The steeper dual edge display, much smaller size of the bezels and phone in general and also the curved ergonomics holding the phone are SO much better than my N4 it is not even in the same ballpark. The display is way better than the N4 (my N4 looked like a 1985 console TV in quality comparison). Hell, I may even use touchwiz instead of putting Nova launcher over the top as I always do. Can you tell I was impressed? Lol.
You know, I've been thinking the last day or so...
With the perfect symmetry of the Note 7, I have to wonder if Samsung has designed themselves into a corner. I mean, how on earth will the Note 8 improve on this? Sure, 4K resolution would be great, 4000 mAh battery, and maybe front-facing stereo speakers... but how much more can they pack into the Note series after this?
Looking forward to some real life reports rather than the reviews seen so far, I was leaning towards maybe waiting for the Note 8 instead but might just get a 7 anyway around x-mas when prices have dropped a bit, Note 4 is holding up well so a 7 would be a want rather than a need type of thing
A great article on using Samsung Cloud as a phone backup:
http://www.cnet.com/how-to/how-to-use-samsung-cloud/
Android 6.0 Marshmallow supposedly has the ability to back up apps AND app data... but I have yet to try it...
256 GB storage, 6-8 gigs of RAM plus their new fancy type fast memory card with the slot that reads regular micro SD as well ( there was talks about for the 7 so good chance we will see it on the 8 ), 4000+ mah battery or even swappable ( probably hard to do and stay water proof but not impossible ) bring IR blaster back, up it to 6 inch screen ( with the design of the 7 it should be done on the 8 without making much bigger if at all ) dual stereo speakers, option of a model with dual sim card for those who want it, plenty they can do and then there is the software side as well
Right there with you Teegunn. Reason I didn't get the Note 4 was because of the increased height. And with the Edge, even though I have one now, it was just too wide. With the new unibody approach, that is one thing that has puzzled me about Samsung designs. The Note 3 was smaller overall than the Note 2,but had a bigger screen, by 0.2 inches. It really does seem realistic that they could increase the Note screen to 5.9 based on the changes they made from the Note 2 to the 3.The Note 3 was the most comfortable for me of the three Note's I have owned (N2, N3, N4), I wish the N7 was a tad shorter (they could have easily shaved off a couple mm of the length). Actually, I do think the N7 is just a tad shorter than my N4, but very little, even though the above specs say it is the same height as my N4. The difference in width is tremendous however - and then the autonomous front/rear curve of the phone - it is much, much more comfortable to hold and is definitely much smaller overall than my N4. Feels so much better in hand.
Sadly, Marshmallow is limited to apps that target API 23 and those appear to be precious few. At least among my apps. I use Helium with a fair amount of success. I choose to back up data only for most apps and save that backup with a label. Then backup those few apps that I can't find on the play store any more (those pesky discontinued apps) as app and data and label those. It is very much slower than TBU but it does work.Android 6.0 Marshmallow supposedly has the ability to back up apps AND app data... but I have yet to try it..
