Last 2 weeks my phone has been "hiccuping" for a lack of better description.
basically it would freeze for a second or 2 than continue as normal
Not sure what app I installed lately that might have caused my current problem. Or it might be process I turned off
( I did turn off Kies Air)
The worst side affect of the hiccup is that it disconnects from my WIFI.
At home this is not an issue since the wifi password is saved, it auto-reconnects by itself with no manual intervention.
I am NOT sure if the disconnect is a result because of the hiccup or another symptom that started happening at the same time due to the same cause.
But when I am at work, I have to constantly re-sign into the network after it disconnects. The cisco wifi requires a new certificate each time and a manual login is required
Any experts on here have any suggestions on what I should do?
Thanks in advance
( I did turn off Kies Air)The worst side affect of the hiccup is that it disconnects from my WIFI.
Thanks in advance
