Root Noticable increase in speed with A2SD?
So I was wondering if anyone any real speed increase using a2sd?
Yes but it doesnt happen until you compare having a bunch of apps on your phones memory as opposed to using apps2sd. regardless, its going to lag a little bit with apps2sd but its alot better than using ur internal memory. People on here have said its supposed to be a little slower because the phone has to access the sd card as opposed to the internal memory so thats why it doesnt get really noticable(or an unnoticable change in speed) once you have alot of apps.
thanks. I didn't think it would make a huge difference. Just trying to ascertain if it would bw worth the headache on this phone.
