Help Notificatio Led
Gremlin256
So any of you get any notification lights for new messages, email etc on your phone?
Only notification light I get is if I do the wrong Knock code (red) and once I unlock my phone (blue).
Tried LightFlow and test option for it shows no light either..
I have checked the boxes for Notification processes for all apps and lightflow..
I'm using Light Manager and it's working just fine. Might wanna try that one out.
Alternately, go to Settings-->Display-->Notification light and make sure you have 'downloaded apps' checked. That allows third party apps to use the LED.
Aargh did not know I could click on the Notification Light option to choose further options bah.. That fixed it..
Thanks dubie7006
No problem. I was super confused about it, as well. I knew I installed the program and had the app turned on but it still wasn't working, that's when I went searching. Glad I could help.
