Help Notification Bar Issue
jennn
Member
Anyone else had this problem?
For some reason my notification bar is no longer sensitive to touch. All the notifications are showing up but when I go to pull the screen down it no longer recognizes this action or that I'm touching it. Every once in a while it will work again for no reason that I can tell.
When I try and press on the bar it usually thinks I'm pressing whatever widget is at the top near it. I've tried moving finger positioning but to no avail.
Any suggestions?
I've already powered off and restarted.
I posted the exact same message yesterday and another member remedied the problem for me. Try double tapping the home button twice then proceed to try "swiping" down the notification bar. Worked for me.
