Root Notification bar settings?
angiembfl
Hope I'm in the right place to ask this question. I'm finally rooted and running CM4DX. I've noticed a difference in the notification slide down pane. It looks like it's from a previous version. Before I rooted if I had a list of notifications I could clear them individually by tapping on the '-' sign next to them. Now I either have to go into each individually or clear them all at once. Does this make sense? Is there any way to go back to the other method?
you are referring to stock GB, CM7 is a vanilla android build, and the features will be different than stock GB which has a moto blur overlay.
On CM7 then you can just slide it away.
Just figured out what you meant by this. Got it! That'll work. :)
There are so many different settings and features that it's going to take a while to figure them out. Is there a specific place I can go to learn about them?
