Help notification from nowhere
hi there
yesterday i receive one notification about my battery life is called battery supercharger but is not from android market and i don't know what to do because my battery is dry to fast in the last week
thanks
I'm guessing in your notification bar its shows a yellow star and then an ad.It is from an app you have previously installed that uses push notification for ads. Go through the most recent apps you have installed, check their settings and disable push notification where applicable.
Get the app "Add On Detector". It finds all your apps that use this air push advertising crap...
