runLoganrun
Member
Hi,
I am having issues with sms notifications. I'm running the custom rom listed below. previously i had "missed call" which had been giving me duplicate sms notifications (with local notifications off), i then uninstalled that along with the sms, mms apps which I replaced with handcent, which also has custom led notifications for sms.
Now I have two things going on, one- there is a little sms icon, just like the one from missed call, sans the red # mark, that always stays in notification area, and when i pull down not. menu it reads 0 sms. So, why is it there? Is it part of Handcent? Handcent uses the icon I picked from it's menu, which is different than what's in the not. bar.
two- still getting 2 sms not. ringtones, first one is default, i think, second one is one I selected, just one new notification though, which is the one I picked.
Now, I still have a ringtone under main settings>notification ringtones, which I assumed I would need for emails, but may hap that is cause of dual ringtones for sms messages, as I have one selected in handcent. ok just got a brainstorm, disable not. ringtone in handcent, but leave custom led, then leave ringtone in settings menu, which should alert for both. I would like to have different ringtones though, for text and email, but missed call was giving me issues, like dual notifications, not audible, but in bar, one i would always have to clear which became annoying. Also, I really like the custom led's, but when there is more than one alert, it just defaults to green, instead of displaying one color, then another.
side question- is there a way, or an app, to make separate ringtones for sms and email? yeah, missed call, i know about that one already, if someone was able to troubleshoot similar prob (dual notifications, with droid one OFF), then I would gladly listen, I used it fine before, maybe it has something to do with the rom I'm using, everything else works perfect with it though.
thanks a lot,
rlr
thanks a lot,
rlr
