Root Notification LED
S
socodef
Guest
I thought there was a question asked about this over at XDA, and I think I saw something for it somewhere, but, is there any mod for an LED notification for ours yet?
I know the one I saw was just to set one led on the screen to blink. I'd really like to have that back!
I have BLN Control installed and am liking that. It turns the light behind the buttons on when you get a text or an email. It does require that you use a custom kernel that supports back light notification.
Have to have the right kernel to use it though. Does anyone know how to uninstall Netarchy's Kernel? I did a wipe data/factory reset but it still didn't remove it.
Are you having a problem with it?
The easiest way is to just flash a stock kernel or another Kernel over it.
just wipe the cache 3 times then flash the stock kernel or another kernel. Matr1x kernel 4.0 works well. i've been using it with no problems with BLN
Just so you know, matr1x kernel has BLN built into it. You don't need to have the app installed unless you want the added features of the paid version.
