Help Notification light flashing after call
Sabresfan2630
Does anybody know why after I answer a incomming call and hang up with them, my notification light flashes green, the only way to get rid of it is to turn my phone off then back on? Does anybody know why this is happening?
This is a known problem(well by all the people i know). Did you try, maybe, calling your voicemail or just making another call and hanging up? Thats how i used to fix mine.
If you are on stock, Just pull the notification bar down after each call & that stops the led light from flashing.
