04stangman
Member
What's crackin my fellow Android peeps? Am I missing something or is there notification light on the note10+?
I don't think so. I don't like that either.Hi @04stangman!
Good Lord I hope not. Do you mean the phone flashes the flashlight when you get a message?
I hate that. It's to distracting. Although I guess that's what it's supposed to do...
not sure what you mean. i just got the note 10+ and i have the settings for edge lighting. it is super cool so far. you have options to change the edge lighting effects. as well as the color of it.
im having zero issues with edge lighting on the note 10+. ive only seen it interact with a few apps as they notify, but its been fine.
perhaps something to differentiate the people who don't have issues with people who do, could be the fact that some may have backed up from an old note 9 whilst others (like myself) did a fresh install.
also there was an update right out of the box, so make sure you received that.
im also on unlocked firmware. if you want to list an app or two that you are having issues with, i and/or others can test that app on our devices to see if there is any consistency...
Thank you for this. I've just installed the free version (https://play.google.com/store/apps/details?id=com.ledblinker).If you prefer something like the old notification light try one of the blinker apps. I've got good results from the LED Blinker app.
https://play.google.com/store/apps/details?id=com.ledblinker.pro
There are many but needs to be re-ported again to the center punch hole. Those same apps works fine on the s 10 line.What's crackin my fellow Android peeps? Am I missing something or is there notification light on the note10+?
I was also fed up with it when i came to knew that LED flash has been removed from the note 10+. recently i got it and its annoying that it was removed. I also checked it with edge lighting but it gives u once only. Its flashes and thats it. So i just found an alternative way of it. As long as you keep always on display u can see your notifications there below the always on display. Thats what i got quite helpful. Samsung really needs to do something to bring it back in coming updates. was huge fan of it.
No but their is an app that can add a camera notification light witch acts like one, it's cool it's called Edge Lighting+What's crackin my fellow Android peeps? Am I missing something or is there notification light on the note10+?
