Hi there,Just thought this may be helpful to some of you. I have just switched from the S3 to the mini and realy miss the notification light as my phone is on silent at work. I done some googeling and someone sugested an app called (No LED)I downloaded it and it does the job quite well. It gives you an intermitent dot or logo (your choice) on your screen. The brightness can be adjusted and it moved around the screen to prevent screen burn. Very customizable (Is that a word?) lolAnyway, also sorry for the lay out of this thread but my work computer seems to not allow gaps ans paragraphs once I press post
Nat
Nat
