GalaxyS2Kent
Still on the learning curve for the S4 from the S2. I would like to set separate notification for received text messages versus other things. Is this possible? If so, can you please tell me how to do it?
Also, I downloaded some ringtones and created a folder on the SD card called Ringtones and another called Notifications. The phone recognizes both just fine. I can see how to set a specific Ringtone for a Contact, just not how to set separate ringtone for texting. I don't want the notification ringtone going off every time an email comes in, for example.
Thanks for any help.
