Help notification repeat for wildfire S
KazWfS1
Is there a way to repeat the sound on whatever notification i.e mail, missed call, text as it only sounds once is there a way to keep it repeating itself till you have recognized it yourself and switched it off? I can't seem to find a ''repeat'' any where
I think with the default apps on most HTC handsets, it will only do it once.
What are you looking for in particular? There are 3rd Party apps that could handle the notifications? SMS Popup might be able to do what you're asking for SMS alerts.
Yes your right El only once. What I would like is a Sound that continues to emit an alarm so that you know you have missed a call,got email, got a message, until you turn it off to see what it is you have missed I have been looking but haven't found anything yet, I know that my wfS does tell you of these missed calls but only flashes or shows you a message, of course if you are not close to your phone you can't see these I want something audible that shouts out at you :eek:
''YOU HAVE MISSED A CALL'' lol
Had a quick search and this might do the job for you?
Easy Reminder.
This looks like just what I'm looking for thank you El.
Iv tried every thing in that little search box ''Notifications/reminders??????????
I don't know how you found it but I'm very grateful will give it ago and let you know how I get on once again Thanks ;)
Yes! Yes! Yes works like a charm Brilliant
