Can I start off by saying this is my first HTC phone and I am very impressed by it.
One query I have is - is it possible to have different notification sounds for e-mail, texts and other apps like whatsapp?
Is this possible? I've got a short mp3 that I want as my text tone
For whatever reason, I'm unable to change my text message sound (which I assume is whatever tone is in the Notifications section).
At first I thought it was an issue with the custom audio file I was trying to use, but then I found that I'm unable to change it to ANY sound, even the ones that came with the phone.
Help?
I don't believe so,I've never bothered to indidualize SMS notification sounds. There are numerous 3rd party SMS apps & dialer apps in the GOOGLE PLAY STORE that allow for a deeper level of customization for each contact.
arty:
WELCOME TO ANDROID FORUMS Jordanf1end!arty:
Do you have any kind of aftermarket volume control application loaded on your phone?
Also,while you're at it,could you list the carrier you're using?
It could possibly be something that others may be experiencing that's unique to your specific carrier.
THX!![]()
In the notifications selection screen, there appears to be no facility to add new ones. (eg in the equivalent ringtones screen there is the + icon top right) I have added sound files into the notifications folder, however, these don't appear in the selection list. Could someone please assist. (the solution is probably easy, but I have not found it yet)
Thanks
